253 lbs. Minus the 17 lbs. of fuel gives a dry wt. of 236.I'm sure I weighed my kick only model (2010) with a tank of fuel maybe.. at around 115kg. Its no featherweight and felt when lifting. Whats that around 250lbs.
If you had bark busters, skid plate, and heavy duty tubes there's a few more lbs. Heavier than the competition, but not by much.
Water in the radiators, oil in the transmission, fluid in the forks, shock, clutch, and brake lines will easily add up to 10-12 pounds.
Go pour a gallon of antifreeze in your GG cooling system and let me know if it all fits.
You can't subtract 10-12 lbs from a bike for fluids - there is a quart in the trans, just over a quart in the forks, and a few ounces for hydraulic fluids and lets say a pint of shock oil. Add all those together, and it's under 3 quarts. 7 lbs/gal x .75 = 5.25 lbs. The rest would have to be coolant.
This is assuming that dry weight is calculated without any fluids, which I disagree with. Dry weight should be without fuel, but some manufacturers just make up numbers on the spec sheet to look better against other brands.
TwoWheels, where's your certified scale and a 2014?
In the industry, dry weight is without any fluids. Not just fuel, but without all the other fluids.
I finally got around to weighing my 2000 GG. It weighed 244-245lbs on the race car scales. Bike info= EC250, transformation kit, KYB forks, radiator guards, skid plate, hand guards, Scotts shark fin, FMF Gnarly, 140 rear Michelin, minimal coolant & fuel.
