Bearings etc.
Yup, everything is nicely lubricated, but not overly so. I tend to over grease everything so we did that.
I added radiator braces and rear brake caliper carrier/rock fin from Enduro Engineering. The braces stiffen up the mounting for the radiators A LOT! It has also made it possible to squeeze with the knees and not feel as if you are going to fold a radiator off the machine
The swingarm looks identical to last years and the carrier fit just right. This is my first year using EE products, and I am REALLY impressed. Great quality.
A note for everyone who will be removing the lighting stuff. When you put it back together, insure that every wire coming from the CDI has a home. When we put it back together there was a lone male spade on a black/white wire that had been connected in the lighting harness. We left it unplugged and there is no spark in the bike. Simply create a mini harness (female spade, wire and a circular ground piece) run it to the coil ground location and your bike will run as intended. This did catch me by surprise as I kicked, kicked, kicked, kicked.......
The weather is looking great out here for the weekends race, so I should have a full race report and hopefully some pictures after this sunday. I will also try and ride this monday at a favorite sand track of mine. I will try and get some video uploaded from there.
Let me know if there is anything else you want me to check for your information and curiosities or if there is something you think I have missed that I should be doing.
