Has anyone used the Galfer pads?
I need new front ones and found some on eBay for a pretty good deal.
Thanks
Thanks
You just need to open up the gap by pushing the piston back in. It is a good idea to clean the piston while it is all the way outOk, got new brake pads, i can fit the outer one ok. but it seems the caliper is to far over on the inside, therefore i can't get the inner one in. how do i rectify this.. I am totally noob to this stuff. At least i am learning something
Brake pads in. I had to take the caliper off to put them in. Not sure if they working fine, will only have bike running in a few weeks. When I left the front off the ground and try spin the well the pads are rubbing against the disc making the wheel feel tight. Not sure if the caliper is sticking.
Could it be from not being bedded in yet, maybe even too much fluid in the reservoir. Are the pads supposed to have heat shields fitted or not?
Sent from my GT-I8190 using Tapatalk
That should not be and the bike should not be ridden that way. What will happen if the pads continue to drag is heat will build up and transfer to the pads and brake fluid and the resulting expansion will cause the brakes to clamp tighter ultimately locking up the front wheel. Simple problem and easy fix if it's the master cylinder as I suspect. Sounds like the piston isn't coming out far enough to uncover the release hole that allows brake fluid to re-enter the master cylinder. There is an adjuster for this on your front brake lever.Brake pads in. I had to take the caliper off to put them in. Not sure if they working fine, will only have bike running in a few weeks. When I left the front off the ground and try spin the well the pads are rubbing against the disc making the wheel feel tight. Not sure if the caliper is sticking.
