Can I remove my EFI and install a Carb?
safetythird
I have a 2003 gasgas 450 FSE. It stall all the time and right at the worst time too. Our local Gasgas Guru says there is nothing he can do. I'm wondering if I can swap it out for a regular carburetor??? Has anyone done this before on this site? I need help. I don't know how to trim the idle up or down. Bike only has 3300 km since new.
Why don't you just try it.....
I don't think you will find somebody who did this before.
Gesendet von iPad mit Tapatalk
Your Guru mustn't be all that guru esq.
You can probably fix the issue with an ECU adjustment. Going to a carb just sounds like a back-asswards way to fix the problem
Try adjusting the throttle body it sounds like the tps is just outside the limit of the ecu. Do you need to open the throttle a bit when you start your bike.
Sent from my LG-D855 using Tapatalk
