MercyFlush
That would be awesome!
Heres is my new ecu map BIN.
http://www.megafileupload.com/dk2q/new_ecu_map.bin
Thank you very much for your time.
Hey man, I'm just going to copy the FSE400 Fuel Table into your BIN. It should work at least for the mean time
Shouldn't take too long
EDIT:
I have put the Fuel Tables from the FSE400 file into the Piaggio file as you wanted, however I wouldn't expect it to work all that well as there are a lot of other things that will be different and cause errors in fuel calculation.
IT's worth a shot I guess.
XDF
BIN
Also, I won't be surprised if you can't upload the BIN you Read from the ECU the first time. I tihnk you probably have a similar issue like what I was having, turned out a chip (LM339) died in my cable
See how you go anyway
