ok, as suspected. you cannot use cr250r fibers, they will fit, but are too thick.. brand new they measure 2.97mm thick. - the gas gas ones measure 2.75-2.85mm thick.
the cr250r steels are identical in dimension to stock gasgas plates. so if you want new steel plates, the cr250r ones are cheaper - i bought an entire clutch pack (steels and frictions) brand new for $44.99 brand new from rocky mountain atv..
you could feasibly use some
cr250r frictions in your clutch stack, but stack height is critical in gasgas. too tall of a stack and you hit the clutch cover/get spring bind, and clutch will drag... too short of a stack and it'll slip badly.
here's what i found:
if you load your basket with new cr250r steels and frictions the stack height will not clear the outer clutch cover and the clutch springs bind. you'd need either a smaller diameter spring wire or a different spring wind,you'd also need multiple cover gaskets or 1 thick gasket (rekluse sells a thick gasket for gasgas)
if anyone needs some never used cr250r friction plates, i'll let em go cheap.
