I'm going to step out on a limb with an answer here.
1. Change the plug. My policy is if I pull a plug out, and it's not to take a reading for jetting, or I forgot when it last was replaced, a new one goes in. So with that, replace the plug. A cheap BR8ES is just fine. A B8ES is fine too. Don't waste your time with an expensive fancy electrode. Just my opinion.
2. Check your air screw setting. On the left side of the bike, looking at the carb, there's a little brass screw inset at the back, left side of the carb, behind the slide and above the float bowl. Carefully screw it in all the way 'till it lightly seats, counting your turns. It may even pay to dab a bit of paint on a small part of the screw and carb to make sure you get the turns right. If you are 1 1/2 turns out from fully seated, it's probably pretty close, but take note of where that is because this setting is crucial to the way your bike runs at small throttle openings.
3. Without ever having to pull the carb or float bowl you can take the top off the carb. From your description of how you ride, and the color of the plug I'd lean out the needle one clip position and see how you like how it runs. A needle change will be the most dramatic thing you can do as far as the way the bike feels anyway.
To do this, loosen the clamps on either side of the carb and spin the top out towards you. Unscrew the cap and pull the whole thing out. Attached to your cap is a spring, the slide, containing the cable and needle. Compress the spring, push the cable in toward the bottom of the slide and remove it by unseating it from it's position and slipping it out of the slot in the keeper. Next take a 6mm socket and remove the keeper for the needle. Look at the needle and take note of where the clip is. The position on the bottom is richest, the position on the top is leanest. Wherever it is (likely in the center), carefully remove it with a pair of pliers, straight out the side (hold the clip with pliers, then push the needle out for best results, not losing the clip is important) and move it up one position, thus leaning your mix out.
4. If you like the results of that, you may want to remove the carb and pull the jets out (we can discuss that in another post) and see what size they are. Likely the pilot is a 42ish, and likely the main is a 175ish. For your style of riding, I wouldn't even worry about changing the main, it just won't matter too much.
