pscook
I rode my 2002 XC300 in anger for the first time yesterday. Well, maybe not "anger," but "mildly perturbed." Anyway, I spent some time getting the bike warm and tried several needles and clip positions before the race but couldn't get it "perfect." Of course, not knowing exactly what is "perfect" I settled on "not too bad, all things considered."
However, during the race, my bike got properly warmed and the idle went right up. I couldn't lower the idle screw so I had to deal with a high idle on some slick descents. I also noticed some knock on high rev under load, and some knock on middle load with slight closing of throttle. I assumed it was detonation, so I did what I could to avoid those throttle positions and conditions. Otherwise the bike ran great and was super fun to ride on the pipe. Wasn't "grunting" up the hills, I let it breathe. It hit like my old YZ426, little bit of bottom, great mid.
Here is where I am with timing and jetting, at this point:
Timing- 10mm head on 5mm screw with 1mm of gap (1* of advance, per the timing thread)
40 pilot
170 main
N3EW on 1st clip (leanest)
AS at 2 or 2.5 turns (can't remember specifically)
Squish is large, can't remember the number. Probably send to RB after I inspect the piston.
Where I want to go:
Remove 1* of advance, should soften the hit, right?
Raise the needle one clip
Lower the idle screw
Proper squish
Am I on the right path? It's hard for me to sort the jetting under proper conditions as I live in an urban area and they don't take kindly to someone screaming up and down the road. I will pull the head this week to investigate, I really hope I didn't erode the piston. I think I will pull the plug after I have a cup of coffee, need to wake up after the beating I took yesterday.
All of this leads to this question- Does a two-stroke get richer or leaner as it gets hotter?
40 pilot
170 main
Where I want to go:
Proper squish
