ec 300 sudden power loss, wont rev
I also have two leaking fork caps only had a full suspension rebuild 2 races ago.. There's always something.!!
Same here. Had new fork seal before xmas and now they leaking again. Going to try the plastic bottle trick on them
My caps are leaking because the rebound screws had split and my suspension guy took the screw out and cut the top off it a made a new head so I could adjust um .it was worth a try anyway I spouse but the two are leaking now and have to be replaced luckily iv found replacements for ok money. .
Sadmx. Mine has vforce3 which has like a twin petal. Other models have vforce1 which are different.
I have just done a compression test and was getting 160 psi for 10 kicks. It's not bad so will not be stripping top end.
I fitted the new reeds today and took her for a blast, saddly no difference. I removed the air filter (just to try anything) and tried again, still no difference. I can only think that it's got to be electrical.
Sent from my i phone whilst doing a tail whip.
Same scenario here mate.. word for word. . And I actually went through the electrical connections too today still no difference. . Im going to take the barrel off again and inspect and if that doesn't work it has to be electrical
Let me know if you have success. I may have found an ecu, the guy is sending me pics of it tomorrow and if it's the same as mine then I will have it.
Can you believe it. The guy who was selling the ECU has decided to keep it after he sent pictures and where negotiating a price. Good fellow biker he was. So going to order a new one tonight. Ouch another expense.
Im going to
Im going to to try get a lend of one and try it first just to see if thats the problem
New ECU is ordered 138 pound including delivery. I'm getting desperate now. Not been out for 3 week. Even my sons kx85 is looking tempting.
Take the coil off your sons KX and rig it up on the Gasser. See if the problem goes away or at least changes.
If anything changes than the problem is either the Coil itself, Wire [HTlead] or poor connection/corrosion in the cap.
I'll give anything a try. That will be tonight's project. Ta
