I have a 2003 EC 300 but this question is kinda general: First time swingarm removal (since I've owned it), left side of main pivot thru-bolt has a 19mm nut, right side has a recessed-hex head with a flattened side that LOOKS like it fits against an anti-rotation flat on the frame.
Removed the nut and assumed the axle/bolt needs a light tapping to drive thru the right side. Installed the nut to protect threads and tapped it HARD with a heavy brass hammer, no budge.
Before I get a bigger hammer, there is no mystery to this, right? The axle should just punch out thru the right side? Any "factory" service manual I can find here is an ENGINE service manual, nothing on the chassis.
Thanks for any dope-slaps or other comments.
