you don't have a problem with your jetting, you have a problem with something different.
- Check the gaskest and the sealing ring on the crank shaft.
- check and clean the carb
- check the reeds
- check the ignition
- check the piston and cylinder condition
- check the air inlet
Your jetting is that lean, that this schouldn't be the problem.
In my opinion the carb is worn out. A friend had a similar problem with his 300, after changing the carb, the bike run like new! Try a new carb and everthing will work.
