Does the engine start if you push and quickly release the kill button when the starter is spinning?
This is something you can do on the KTM 2 strokes with external starter. This tricks the CDI into producing a bigger spark, if I remember correctly.
The KTM starters would progressively slow down due to friction build up in the bendix and crown wheel. It might be worth stripping, cleaning and lubing the drive train to eliminate that possibility.
Is there any way to look up a cdi by serial number to see if it has been reflashed? Before I went to buy the bike the dealer told me it was done. When I got there it only had one dot on the bottom so it wasnt done. He said he would get a new one mailed to me so I left with the bike. The new one he mailed has the two dots but now I?m wondering if he just drilled the second one in himself. Running out of ideas as to why the bike won?t fire. All of the electrical connections look good.
Most likely a bad starter, which seems to be the problem on most of them that do not start after the wire upgrades and reflash. These starter motors seem to be rubbish.
