Jakobi
Hi everyones.
Ever since day one my EC300 has been a real viber. But of late a bit more noticable in the mid range as it comes onto the pipe. I checked the engine mounts and slightly nipped up the front lower, which reduced some of the vibes while on the stand but the bike still gets a real buzz on right before it explodes into band.
My rear pipe mount is broken and has been removed. The front one is looking pretty shagged out. The O-rings and springs are good though. Would these create extra vibration? I have removed the lower front pipe mount (rubber part) and solid fixed it. I will be taking it for a test ride to see if this reduces the vibes. Either way I know I'll be up for a new rubber mount as solid mounting is a sure way to crack the pipe.
Any other ideas why the bike buzzes so much?
