Chris I run Saber (at 75 to 1) in my 250 all the time and lug the motor a lot with no problems but I couldn't run it in my 300 without loading up. People who ride a lot faster than me (like yourself) may not have any problem but 300s are usually run easier than 200s or 250s so they generate less heat. Combine that with rich jetting which also make the engine cooler and you can load up your engine easily. Are you going to WUDI this year?Why is Saber bad my bike runs killer on it better than dominator???????
Not necessarily, a number of things can and do affect an engine "loading up" because a number of things affect how hot an engine gets. Jetting is most important but other things are in play as well. Not everyone can properly jet a carb so why not change the easy stuff first to see if that will be enough to make the problem go away?As mentioned you can swap and change oils til the cows come
home but unless you change your jetting your symptoms will remain.
Choose an oil based on price/smell/performance whatever then jet to suit.
I'm going to take to the Q silencer with a hacksaw as soon as I find a reason to have it off the bike. Probably shock revalve time. I honestly think its the root of the spooge. The bike doesn't really smoke any more heavily than the 2010 model, but the spooge just keeps on coming.
Jakobi - what are you checking in the power valve? That its clean or something else?
