theexception_03
As said before,your nearly there.Drop the pilot a size or two then go to clip 2.Remember,one thing at a time.
Thanks, will do that on saturday, got my fingers crossed.
The idle screw is only about 1 turn out, so yes its in alot.
Do you know what number slide is in it? You'll always have some burbling at light throttle too. If you lean things out to get rid of all the burble under light throttle it will be too lean to produce good torque when under load. Have a play with the air screw and see which way produces best effect at 1/8th and feel how it effects the power. Seems you're pretty close! FWW my bikes liked the 42 pilot and J diameter (N3EJ) or 40 and W diameter (N3EW), but this is using a 2010 model and a PWK ASII. I'm located Far North Qld.. Hot and humid, with a few hundred meters of elevation.
N3EJ is leaner, but only on the needle diameter of the straight section (at 0 -1/4). The needle diameter, pilot, and slide are all working together here, which is why it tends to be a bit finicky. Change one and it will affect the others too.
Work with the AS and you'll get there![]()
Thats why you have had to jet it so lean if its overflowing. You need to confirm the float height again, but more likely is that a float is damaged and sticking, or the viton tip valve that lets fuel flow in has perished and isn't sealing correctly which will also cause overflow issues. You should be able to tip the bike 45 degrees to either side before having the carb overflow.
I have just put a N3EG needle middle clip,in with a 38 pilot, 178 main, a/s at 1.75, and this is perfect for me. i played around with a NEDW but found it to soft off the bottom.
this is on my 09 250r, which also has the screw top AS I carb...
in vico.
I took the bike into the shop cos I needed it checked out after I tried heaps of different settings, they repacked the silencer and checked the PV, which was all good.
They also changed the jetting including the needle (with out asking me) this is the setting they put in
N3EF #3
MJ 175
PJ 40
I will take it out for good ride tomorrow.
Its not that lean, and my bike was always a bit of a lean freak too. In general I think being in Australia there seems to consistantly be a bit different to the states too. Must be the difference in fuels.
Hi tim,
i would be a little careful about following what others are using in different countrys too, lots of different fuels, this will change jetting alot.
you have plenty of needles to play with to get your bike going well, follow the process as described by jakobi, (thanks for that by the way, cleared a few questions in my head.) and you will work out what is best for your bike...
and if you want, for comparison, as im just over in central victoria, riding similar altitudes, temps and weather, and fuel...
09 250r (with the older scew top carb)
40pj although im going to try a 42 yet.
NEDW 2nd clip
178 main
7 slide.
air screw is at the moment on about 1 turn but i keep playing with it and hence my wish to try a 42pj..
i cant say its perfect, but its bloody close...
dont worry about your cdi or anything yet, try your jetting first...
good luck.
