Hello, I am looking to do my first top-end rebuild on a 2007 EC250 that I picked up a week ago. Previous owner stated that it was on its original piston/rings. Starts and rides fine, but there is strange vibration noise. It sounds as if there is some rattling/vibration noise around the engine area. Maybe the Rekluse or the Power Valve? What else could it be, a bearing?
I thought that this would be enough for a top-end and fresh start.
I have a few questions.
First, a "B" is stamped on the back of the cylinder head. I am assuming this is the piston size that I need to order?
Second, is it as simple as replacing the piston, rings, gaskets or do I need to consider a replate, bearing change, etc?
Third, I noticed that the Power Valve is completely coated in carbon. Should I just pull it out and clean it with contact/carb cleaner?
Fourth, do it all myself or take it to a GasGas expert 2.5 hours away?
Any other tips or suggestions?
Thanks for the help guys!
