flasher relay
pigpen966
Hey All, just hooked up some LED turn signals on my GP. They are lighting up slightly. It has the EC harness I'm guessing because all the hook-ups were there. I looked at the wiring diagram and figured out which wire was left and right. Are the stock flashers LED? Do I need to put a LED flasher relay in?
If anybody could help a brother out it'd be much appreciated.
Generally LED indicators need a solid state type relay, one that dosnt go click click. They are super cheap now, can get one for a few bucks, should sort out your issues
Except gassers now have the flasher relay as part of the left hand switch block...
You?ll need to fit some of the led resistors to each side of the blinkers instead. Not the way I like to do it but I had to do the same when I fit up the Click n Ride indicators to mine.
