SOLVED!! - Float experiments - what would your bike do??
Testing the results of the head modifications I ran the following set up:
Pilot 45, DDL #4, 185 main, #7 slide, Air screw 3 turns out (EC250 - 2005)
Bike pulled like a train, throttle only wheelies in 3rd/4th gear no problem
Seemed pretty rich based on smoke from pipe and amount of fuel used. Very sputtery at 0-1/8 throttle and would load up in slow sections taking a gear or to to clear out. Idle was non existent, even with idle screw wound in too far (spring bound) still no idle - it just didn't even try to idle
I thought I would go the the other extreme and throw a 38 pilot in when I got home to see if I could get some idle - I reckon this is a pretty lean set up with the large section needle (ddl) and a 38 pilot. I got it too idle (just) with air screw at 3 turns out but not that well and idle screw had to be really far in, any attempt to set it off coil bound and bike stalled. (air screw setting obviously didn't have any effect)
So i figure somethings not right - surely I don't need lower than 38 pilot, and or an even larger needle. So as an experiment i let it idle (1000rpm ish) and turned the fuel off. After a moment the revs rose, not a gradual rise but a definite step change - suddenly the bike was at 2300-2400 rpm and I could return the idle screw to more sensible settings. The 38 pilot was now way to lean with a bog response to snapping the throttle. However the bike idled really well like this for a good 3-4 mins before eventually emptying the float bowl and stalling. I reckon a larger pilot would put right that bogging and I would have idle screw setting that brought the air screw back into play - I will test this next time.
I am now thinking the fuel level in the float could be an issue - I have checked the float setting too many times and I am positive its right. Can the fuel level get to a height where it screws up the idle circuit?
Is it possible the fuel level is too high when running? Could it be caused by vibration, or does the valve simply need renewing?
Does anyone else's bike act this way when the fuel tap is knocked off?
I refuse to give up, I refuse to give up......
Cheers Andy
Cheers Andy
