What power characteristics have y'all seen with the shorter Q cans ? Broader power band? Narrower ? Better/worse off the bottom, mid, top?
You could use a powered miter saw with a regular blade if you turn the blade around backwards and work slowly. I've done that a number of times to cut very thin metal or wood.If Any body has a miterbox saw this will make easy work of cutting the Q down.
carbide blades will cut Aluminum. if you take your time cutting.
