Fuel map questions for '05 FSE 450
cobrad
I have obtained a service bulletin titled "tuning for races" with instructions to disconnect the yellow and blue wires under the gas tank for a richer fuel map. It has been suggested I might want to install a toggle switch so I can instantly go back to the lean map if necessary. Is there any reason one would want access to the lean map?
From what I have heard, most switch from the stock map to the race map and never go back. The map that comes stock appears to be aimed at meeting emissions standards - given that, I wouldn't think you'd need to switch back to it for any reason. Me, I would just unplug the wire.
I have disconnected it, works fine.
Anything else interesting in the Service Bulletin, cobrad?
I have a couple other bulletins addressing grinding the throttle stop and starting the bike. Good info I got from the local dealer. The dealer I bought my bike from were nice guys, but, by the service managers' own admission, knew nothing about the bike and were able to offer no help or insight.
Take 5thousanths off the decompressor on the cam and they start mucho better.
