Have you changed to clip4 in your latest test,you dont say
Try clip2 then or if you try 172 stick to short full throttle bursts.if it helps get hold of a 178 and 175.remember the main is only 3/4 to full so if its blubbing before that point...clip2.
With the main you want it just lean enough to run clean.whats your altitude/temperature?
My bad,i just reread last page.i may have to reread 20 pages shortly to remind myself of the whole picture.
If jet changes arent noticeable it tends to imply something else is going on.apart from mechanical setup that jakobi has mentioned,im back to thinking,float level,filter,petcock intake,fueltank breather
Stick to 1 change at a time,your post suggests you richened the clip and leaned the main at same time.one cancels the other to some degree
