LTR's Jetting kit is not a cure all end all. It is that magic needle that, once you find out the right brass, will make you one happy camper. It's a starting point for where you ride. I have the LTR jetting kit in my 300 and started where you are. I ride in the 500 to 4000 foot level, and my bike runs great from the valley to the peak. I will say it took a while for me to get it right, and I may still fiddle. I'll explain in a minute. Bottom line, you're too rich. Go to that 42, lean the needle out another position, leave the main alone for a while, that probably won't matter unless you are riding on roads wide open all the time. Anyway do all that, but here's the key. Your air screw has a LOT to do with the way the bike runs at low throttle openings.
Now my explanation of my further fiddling. I'm running a 45 right now, and I'm 3 full turns out on my airscrew, which is screwy, but my bike runs AWESOME! It has better throttle response than you can imagine. There is no drool from the silencer, and there's a faint brown ring at the exhaust tip at the end of a ride. That said, I may put in the 42 in search of going to a more standard 1.5 to 2 turns out on the airscrew.
