Leon_gasgas
Do Not Do The Stator Mod!
Hi!
As I wrote yesterday I connected only the yellow wire to the "trailtech" dc reg. Today after 2 hours drive I measured the voltage at the battery with the front light on. It was between 14.40 to 14.75 volts max (high rpm). Pretty good and better than the 14V when I had connected both stator wires together! The battery's cycle use is between 14.40 and 15V. So the whole system is OK. I have to say that last week the trailtech helmets lights flickered sometimes. The hid headlight was ok. I am sure that they won't flicker again! Steve the measurements you gave are really off. Is it a gasgas 2K3 or KTM 2K3?
Many Thanks you put here the link from bajadesigns with a clear diagram on how to go hid without modifying the stator!
Leon
Hi!
Leon
