HP wild 450 CDI issue
Hanger17
I am hoping for some info having just bought this quad about 6 months ago and fixed most issues but still cannot get it started. I have traced this to the crank sensor electrical. Sensor tests okay but getting strange voltage readings. I think this may be down to the pins going to the ECU/CDI. So to start with can someone give me the pin numbers and colours the ECU.
With no ignition I get 12v at pin 5 and grounds are pin 16 and pin 23.
With ignition on i get 12v at pin 5 17 19 26.
Are these correct? The gas gas manual electrical page is not great as the numbers are illegible. Any help would be great as i have spent a bit of time using facebook groups and had no help.
At the end of the manual(page 62 of the pdf or 64 of the webpage) You can find a wiring diagram that includes the ecu connections with colors aswell. It is for the bike not wild but ECU should be the same? The legend for the color codes is on the left hand top side. I had to chase down an issue with the fan and its relay and for a 2006 450 bike the colors matched correctly. The quality on this one is not great but I would say its usable. Or did you already try this one?
