That's is not a valving problem.  Jump landings are controlled by low-speed circuitry, and is dominated by clicker settings.  Go in a few clicks on your compression clickers.
JayC
I disagree, it is a valving issue...and addressed thru valving, jump landings are a high speed issue.
I think he may have too much float, along with a incorrect setup for what he rides ,,,just MHO.
It took a lot of valving changes to get the marz forks on my 08 300 to work how I want them to, I suffered through a lot of sacrificing plushness vers firmness.
When the fork was plush on the roots, it would hammer over logs, g-out and drop offs.
When I stiffened up the BV stack to compensate it was too harsh on the roots.
My first valve theory was wrong, I now know the firmness is found in the midvalve (IMHO), so I went back to the plusher BV stack and controlled the fork stroke by way of the mid valve.
The midvalve is like a paraschuite, the trick is to get it to open at the correct time...too much float would cause the fork to dive too quickly into the stroke and give a harsh feel,  too little and the fork in essence would lock / deflect and again feel harsh.
So, I went with stiffer springs to get the fork to ride higher in the stroke.
Set the BV up with a 2 stage woods/lighter stack, using a 10, face shim so it would open quickly for the roots/rocks.
Then the MV I also used a 10 shim for the same reason, 2 stage stack, stiffer MV spring which also helps it ride higher in the stroke, then I limited the amount of float.
The more I tightened up the float the plusher the ride and more compliant the fork became....originally I had way too much float, I thought getting more oil to flow would make it plusher....was I wrong.
I lowered my oil level until I felt the bottoming resistance was good for what I ride.
Also I had to really stiffen up the rebound stack and I mean a lot.
After being in and out of the fork 6-8 times I am super pleased with the ride quality.
Just a note: I went thru the same thing with my CRF 250, it was great on the MX track, but I was invited out to a outdoor style track, lots of bumps  and I got hammered....I had the float set at .20, I opened it to a .75 and what a difference.
My point is the right mid valve set up is cruical to a well performing fork...One of the best tuners I know said the mid valve is where the magic is found...and I agree!
