Thanks gasser Nate and F5 for the reply. Yep, your correct I have blocked off that hose. (wrong thing to do??) I have also blocked off the intake and exhaust as well as the powervalve drain tube. I was under the impression that if I block all external outlets then it should be able to hold 5psi..
Can someone please advise me as to the correct procedure for a leakdown test. Pressure is input through spark plug hole in cylinder. I am pushing about 5 psi through it.
thanks in advance again.
Jc
I have built a fair few motors in my time mate, thanks! Yeah you can tap it out from the other side.thanks gasser nate.. Your a man of immense knowledge. My next question, can I push this bearing out from the left side if I remove the powervalve??
regards
JC
