I picked one up to try, hopefully there's enough clearance when I add the estart
I decided not to make one of these spacers and go the Elvis route instead. Hopefully I'll be able to ride some with it before the end of the season here.
Only 10 and 15 mm
Some friends tried 2x 10 but the result was similar to the 15 mm. But the 15mm fits better and looks better.
You will be happy for sure
Sorry, but no. There is not enough space for a spacer. The max you can put between is 2mm but that's not worth it!
I made a CAD model for a spacer version but it is much too expensive for me as a privateer to pay for. Making 5 pieces would cost more than 150,- euros per piece. The problem is the high milling volume which means time on the machine.
You tried laser cut?
It's a 3D PDF where you can see how the e-start cover would look like.
The pdf cant be opened, could you upload it again?I hope you can open the pdf file.
