EC300 with lectron won't idle unless I set it high
I have a fresh engine (top and bottom)
I have worked with Lectron to no avail
The bike will idle for 5-10 seconds, but then drops to a super low idle and dies within a few seconds.
Known:
The reeds are not sealing perfectly on the corners (slight wear). I do have new reed pedals. (Would this cause issues/ normal wear?)
When I pressure test, I am getting a lot of air loss past the power valve (normal?)
When starting I use the choke but have to turn it off within about 10 seconds, just seems super rich with choke on......??
I am at a point where I think the carb is on the lean side since the idle is a bit eratic when I go any further.
There are no air leaks that I can tell.
Any help would be greatly appreciated. I love the bike, but if it's not going to idle, I may not be a Gasgas fan much longer.
Known:
