Okay, as I feared knowing the folks on this site, we have someone "foolish" enough to try this thing out (Steven Beane, look for a PM). Realistically, this should work well if I can find the right setup between Carbs, needles, and the power jet. Luckily I have an application guide from 1981 that has suggested needles for most dirt bikes made so I just need to pick what vintage bike bore and stroke most resembles a GG (Steven, we need to decide 250 or 300) and go from there. Also, Lectron recommended using a smaller than stock carb as they claimed their carbs flowed better without obstructions...Should we go this route, too? As a final note, most folks only know about Lectrons what was written in magazines at the time and most of the tests were done early in their development. When they started, they had few needles and you often fell in between those with your application. By 1981 they had over a hundred different needle combinations and each needle was tunable itself by screwing it up and down in the slide (then secured by a set screw) for different conditions. This should be fun!
Eric
