I'm mid way through servicing my linkages and despite being very careful, these two washers dropped out of "somewhere" while I was tapping away at the swing arm bolt
I've taken a photo of the offending washers against the linkage arms for reference
They seem to logically (and physically) fit on either the upper or lower shock mounts but I'm not sure. Maybe on the lower shock mount where it bolts to the linkage, with the wider/inside part of the washer on the bearing race, and the outside part protecting the oring??
The only things that have been disassembled are what you see in this photo, plus the top shock mount on the frame.
Any help or references to linkage diagrams is much appreciated.
