LTR Jetting to EC 200 -06
Mikael
Hi guys ,
I would like to have some tips for - 06 EC 200 jetting .
Slide nr 5 is in carb + PV-cover + DEP-enduro silencer ( long ).
LTR - tips ? ( As we know the factory setting is odd...)
To where/whom I can place an order for LTR-parts to be sent to Europe ?
Mikael
Hi Glenn & thanks for your reply ,
France & Sweden = Do they have same knowhow as Les has ?
-I just try to avoid so called " maybe knowledge " ...
Once you get the LTR jet kit, here is what I've worked out for my EC200. It's a 2003, similar setup to your 06, only I have an FMF Fatty/Turbine Core II silencer. This is all figured for 270 M (900ft) elevation. I'm a tad on the rich side, but not plug fouling rich.
Temp °F __Main__Slow__Clip__Air Screw
100°-120°___170 ____42 ____3 ____½OUT
80°- 100° ___175 ____45 ____3 ____½ OUT
60°- 80°____ 180 ____45 ____3 ____½ OUT
40°- 60° ____182 ____45 ____3 ____½ OUT
20°- 40° ____185 ____45 ____3 ____½ IN
0° - 20° ____190 _____48 ___ 3 ____½ IN
-10°- 0° ____195 _____48 ___ 4 ____1 IN
Below -10 __200 _____50 ___ 4 ____1 IN
Hi Todd ,
Thanks for your input .
-06 2-strokes has V-force reeds and different manifolds and different slides than -03 ECs and I assume that jettings should be different too , or ??
You can email or call Les directly. If you bought a kit he would be happy to help you.
Hey Todd,
Your jetting table is much appreciated - you posted it once for me before, but could you explain the air screw portion? What is the starting point for the 1/2 in, 1/2 out etc.?
Thanks,
~300
