My '00 uses caged roller bearings on both sides.
You mean caged BALL bearings, the newer bikes use a ROLLER bearing on the ignition side.
The '00s use 6306 C3 each side. These are available in many brands and grades, some good, some junk. When I rebuilt my '00 low end I used M306 C3bearings. These are heavy duty equivalents of the 6306, with an extra ball and a machined brass cage. From a bearing supplier, the cost was about the same as the standard bearings would be from the dealer. I beleive these are only made by the quality Euro and Japaneeese mfgs., not duped in China with substandard tooling and materrals.
This bike is owned my member Bucksnbikes still runs today with that lower end.
left side crank seal, ME250112009
right side crank seal, ME250112008
These are from a 2001 engine breakdown. Left seal is the same, 200, 250, 300.
Right seal is different for each.
would the caged ROLLER bearings for both sides fit an '00 300 engine?
i have a feeling mine might have this setup.
hardly any up and down play, but some side to side play... seem logically if it would have this setup.
will measure play by this weekend and determine eather to pull engine apart or not.
