MotoSeat Covers Available for 12s and 13s
I also just received my MotoSeat cover to go over the tall Guts foam for a 2013 300. I'm still working on getting it installed an will post up some pictures when done.
11' seat cover
I got my seat cover in this week too. Hopefully I will get it on within a couple weeks. The cover is going to look great- as long as I install it well :o
Here is a pic, it's got the tall guts seat foam. I had to cut the foam for the bolt hole and I added a Dzus fastener.
Just received my cover, any tips on how to do the bolt hole. Have few ideas but experiments can turn out costly
You could stretch the cover over the existing one and line up the screw, then mark it, or if you already have the new cover fitted sharpen (to a point) the end of a screw the same size as your seat bolt and drive it up from the bottom - the center of the required hole will be obvious.
Ok was looking at this as I just received my stapler but how do you remove the seat bolt housing? Or do you just make the hole and stretch it over the housing?
(In "housing" I mean the red anodized part that the bolt goes through)
Bump? I can't remember what I did on my 2010
