Multifunction switch
Rman227
Hey all, would like to ditch the large multifunction starter/horn/headlight, etc switch on my 18 ec300. Does anyone know if the 19 starter button will plug directly in? Or if there is an aftermarket, smaller assembly that will work? Thanks
I made up this plug to replace the original harness. Headlight is hard wired to low beam and the 2 smaller plugs are for starter button and fan.
Wiring
Hi Wuzofoz
Do you have or can you share a wiring diagram?
the guy I got the bike from replaced the original SW with only start engine sw.
I have to wire all back to the original.
He make changes that I like restored to original
Thanks
