Need 05 up 250-300 bottom end and swingarm linkage
Stoby
Bronze Level Site Supporter
My new to me 05 250 cases are junk! looks like suspension had previously been so worn that it elongated the mounting holes in the engine my 01 engine doesnt fit so ........... need cases, linkage and swingarm bolt
Any help appreciated
Thanks
Soon to be poorer Stoby
How could that happen? Are the swingarm pivot holes in the frame worn too? Loose pivot and motor mounts?
Have them welded up and remachined. If no locals are capable call Ron at RBD he does general MC machine work.
Don't know
I'm only assuming thats how it happened.I rode the bike 3 times ,seemed a little buzzy to me so i checked everything and retightened .Still vibrated finally stopped when i pushed down on the cases.investigated to find the mounting holes elongated and the pivot mounts and shaft ruined.previous owner claimed to have replaced all suspension bearings very recently.My thinking is he waited too long ,maybe didnt notice the problem.........If i have to i'll take apart and get machined ,figured buying a bottom end would be about the same
Frame ok
Frame seems fine checked clearance= ok and shaft only shows wear(lots) around suspension/motor mount area.
