Hi Guys,
I've looked and looked through all the float adjustment posts, lean conditions, etc. I can't find one that matches my bike. ('10 ec300, with pwk carb) It did this before and after the RB carb mods.
Here's the issue-
When I'm going up a steep hill, my bike fluctuates in RPM with constant throttle input. It would also leak out the overflow sometimes just over the kickstand angle. I figured I would adjust the float height and be done with it. The 14-16mm dimension does not apply to my bike. I took it apart, measured 17mm, if I get it any lower than this- it won't compress the spring on the needle. I put it at 18mm just for a change, since I thought the fuel level was too high (puking out the overflow at shallow lean angles). The pictures found on the forum showing the float height don't look like my float. The ones in the picture look much more low profile than mine.
I took it for a ride, ran well- then I pulled a wheelie- not super long (200 yards), and it started cutting out (just like it would on a hill). All my other bikes have been able to sustain fuel for very large hills, and wheelies as long as I wanted.
I'm going riding tomorrow- any thoughts would be VERY appreciated.
Tim
Here's the issue-
Tim
