Its actually a DGK.
Its significantly leaner than the N1EF. Comparing 42 N1EF#2 175 to 42 DGK#4 180, they start off the same at idle. The N1EF increased to approx 20% richer at 1/4 throttle, and then tapers back down and they run very similar from 1/2 throttle to WOT.
IMO the DGK will be far too lean below half throttle. I'd almost expect it to hesitate and not even take throttle below 1/4. A shorter L1 height
such as a DEK or DDK would probably work much better.
What is the problems you are facing with the N1EF currently? What would you like to improve on? Whats the temp, alt, humidity, pilot jets, clip position, and main?
