so.. you have a '12.. did you have any problems with the cover leaking?
Where in Sweden are you located? I just might head your way some day and do some measuring, if you're not too far up north.
I just love those Swedish single track's do you have any near your place?![]()
I had no end of dramas with my 12 clutch cover.Just could not stop it leaking.
Ended up going to a solid cover again, not sure if it is an older type or a 13 type though. My bet is that it is the older version.
Cheers Mark
Where did you buy your cover?
Just checked the Spanish and German sites and they are all out of stock on the '12 cover..
The '12 cover is fine after being lapped flat on a glass plate, along with the ignition cover. Mine weeped a little stock now no issues. That said, you have to wonder if the oil scavanging vanes on the inside were ever tested since GG was so quick to abandon them. I suspect not and that it was a "shotgun" approach to solving the problem. Honestly they can't hurt, but my older bikes with the alloy covers were just as good. I think its the basket/pressure plate more than anything. Actually they were always good until '11.
Flat is flat, so if its done right it should be good I would think. Problem is its tough plastic and a little slow to do. If you don't care about easy R&R of the cover a little Yamabond, Threebond, etc. should work good.
