Newbie bought 2004 EC250 - need help with parts
stuckinatree
Hey guys, I am a newbie to GG (I am a converted KTM rider).
I need help in identifying basic parts like brake and clutch levers, throttle cable, and brake pad replacements.
Any specific help is appreciated. I don't want to be let down with this GG purchase, but finding parts has been time-consuming to say the least.
Thanks,
Brian
moose racing has both the standard length clutch and brake lever. look under the oem replacement lever section. the throttle cable, you are best off calling up gofasters and getting their 1.5 inch extended cable made by motion pro, it provides a little wiggle room and will run around 35 bucks if i remember right. other bikes like hondas and ktm use the same carb and basically the same cable, but there is a fixture at the carb end of the cable which makes a bend to fit around the gas tank, so the other brands cable will not work. brake pads off a honda cr, 87-01 (from the cross over list) GoFasters will have all of the parts you need. the link to their website is under the parts tab at ggor.us
i hope your gasgas will not let you down. yes, sometimes parts can be hard to find, but they are a fantastic bike. good luck!
by the way, it is often easier to call gofasters, rather than use the website. the website is functional, but it has its quirks. i have called multiple times and they are knowledgeable and fast.
Yeah, first thing to do is go to the parts crossover page, http://www.gasgasrider.org/html/parts_crossover.html
There are lots of other things that will work also, just do a search. Your best bet is the classifieds on here, lots of stuff to be had very reasonable (usually).
One great thing about GG parts is a lot of times they will list the size on gofasters so you can find a universal replacement for things like bearings.
Thanks guys for the quick response. When the crossover list states '87-'01 Honda for brake pads, does that mean it only applies to '87-'01 GG's as well? Or, will those pads work on my 2004?
The pads will work for any GG with Nissin brakes. They are from a 87-01 CR250 and also the same ones on my XR650R and the fronts are the same as my sons CRF230, so I am sure there are many more they fit.
Ned - Where did you get the levers from? How about the clutch lever? Will '01 cr250 levers work for the clutch as well?
thanks again!
Brian
The '01 CR clutch lever won't work, it's not hydraulic on the Honda ;)
Take your brake lever down to your local generic bike shop (Cycle Gear, etc) and they will have a front brake lever hanging on the wall. It's in the Honda section. Don't ever mention GasGas for parts, they will automatically tell you they don't have it. Same goes for front and rear brake pads.
