newby question
there should be almost no vibration. i'm so used to no vibration on my 300 that every other 2t i get on i notice the vibration right away.
You guys must have good ones.. Mine zings through the bars and pegs quite a bit. Always has. You soon enough stop noticing once you're trying to hold on though..
My 2010 300 shakes like a paint mixer. It's the thing I hate most about the bike, because it puts my hands to sleep and really makes racing hard sometimes. Everybody that takes a spin on it, comments on the vibration. Yes, the motor mounts are tight.
I've thought about trying to get the crank balanced by some machine shop. Not sure if this is worth the effort or not. In all fairness, my Husky WR250 vibrates almost as bad.
I used to notice it through the pegs when riding easy/flat stuff. I try to stay away from that type of terrain anymore.
My 300 has a small vibration, but my 97' 250 is smooth as butter dripping off a hot biscuit!!!
But, nothing compared to my old KX250, that thing would make my feet ache.
Yep! On the stand I give it some gass and then as the revs drop theres a noticable vibe that rattles the pipe if the o-rings are worn and is also visble on the plastic side guard over the pipe. Its only really felt in the pegs when cruising at a certain speed. Somewhat like a massage. Other than that you just feel the vibes build a bit with the revs and the power. Not annoying while riding. Mines also a 2010.
I threw a leg over a friends 2011 and his was sooo smoooth.
My '11 300 vibrates a bit when you're sitting still and you rev it up. I don't actually notice it when I'm riding. I think my GG vibrates less than any KTM I've ever thrown a leg over.
It appears it comes down to individual bikes and how much we all notice. A few things to consider.
Flywheel balance and Crank balance would be probably most likely in causing the variances. I've also read that certain bar/grip combos can change how much the vibes are felt. My 2010 uses the Twin walls which apparently transfer the vibes quite well.
That was something I was worried about too when I went from a 250 to a
300. I had ridden friends' 300 KTMs and found the vibration annoying. But on this 300, I don't notice the vibes any more than on my old 250.
I don't know why but the older Models are much smother and vibrate not so much. The newer Models have more vibrations but in my opinon still ok.
Check the trans oil level, make sure it's not over full.
You can neutralize the motor by loosening ALL the motor mounts, including the swingarm pivot bolt and the head stays.
Start the engine and rev a few times.
Retighten all the motor mount bolts-start at the swing arm pivot and work your way to the front.
The head stay bars should be parallel and not squeezed together at the head. You may have to shim it if it is.
The exhaust pipe should slide on/off without binding.
Basically, you're looking to eliminate any vibration causing harmonics.
Good advice there..
Worked a charm on my 02.
