4.9 & 5.2 is the weight rating of the spring. Most Gassers came with 5.2 as stock springCan anyone tell me exactly what the numbers keen on 2 x online springs I have 1 596-08/4.9
2 596-10/5.2
Cheers
Easiest way to check is to put the bike up on the stand. Undo the bolts for the dog bones and pivot out of the way, undo the lower shock mount and then grab the swing arm and move it through its range of travel. Should move smoothly and not bind or have any play. If you don't know when it was last done I'd be pulling the entire swingarm and greasing all the bearings.
so what is the difference where one spring is 10 and the other is 8? what do those numbers mean?
I'm only having a guess, but could it be the diameter of the wire coil in mm.
8mm does sound a bit small but 4.9 is a light spring rate.
Should be a 06310-11/54 but I'm doing that from memory (58=13 56=12 54 should be 11)
Yep, your spot on as i've recently found out.
