? on marzocchi 48s
flognart
The owners manual for my 2013 250 state the compression an rebound adjustments on my forks are the opposite of what the marzocchi manual states. Which one is correct? Maybe the 80 degree temps fried my old brain in the woods today.
Compression up top , rebound underneath. PFP is the 22 mm tri sided bit on top of the forks:D
The gas gas manual dates back to the early 1900's...
Always go with manufacturers specs. Gas Gas very likely holds some kind of record for most variations (brands) of suspension used on a dirtbike. Different models kitted with different specs, and different brands from year to year etc. Even in the current models there are 45mm OC Zokes, 48mm OC Sachs, 48mm Sachs with Ohlins TTX, and 48mm CC Zokes. Its no wonder some things are lost in the owners manual.
Thanks to you too Jakobi, that's why I like this forum. Something was telling me comp on top rebound on bottom but I had to ask.
