I've always got all my stuff from GoFasters and they sent me a Wiseco. Then my buddy gave me the info I mentioned in my original post. Hall's only has Wiseco too. Ron Brundidge has none.As much un-lucky misshaps i have had with Gofasters.com they got em in stock. Otherwise a Gasgas dealer can get them in for you.
Brian,
Is it a coated piston? Wiseco is a forged non-coated piston. If you start off loose its not going to get any better! You should have a "C" size Vertex. I always go up a size on the first top end. Vertex is OEM on the '07+.
It has a black coating.Brian,
From what I have measured on several bikes, the clearance is fine for a size up.
The piston must be a Vertex of maybe an Athena, both coated cast pistons.
Why would you want a single ring piston? That would be a step backwards for a low reving torque monster like the 300. You loose compression and life goes down as well. I'd prefer a dual ring piston for the GG 125 thats ridden in the woods.
I told him I had a B cylinder. Apparently they only have size A....tell them you need a C size
