gassi
We have changed the CDI around with no difference. We are going to pull the clutch sides off to take a look at the difference in shims ,spring etc. There is a difference some where and we have covered everything with confidence other than this subject. The 06 pulls like a mild 500 and the 08 is a good 250 but i know of 250's that are stronger.
The Trusty's power valve adjuster would be a real nice add on but if it wouldn't give the same power delivery as the 06 I'm not spending the cash to find out. Just by the seat off my pants I would think it would limit the opening of the PV more than boost it. JMHO.
Ross, the adjuster screw 3 is for what I suspected in the linkage position . Thanks for clarifying. The shims and spring is what I would be looking at to adjust on rate and timing of the PV.
I would really like to know what is change in EC 300 motor after 2006...
Let's try keep this thread alive, because I think there is many who is wondering with the same question?
I have 08 EC300 and I am very disappointed motors bottom end and mid range torque compare to 06 EC300.
-Look like it's not matter of CDI
-I am playing with the powervalve spring preload too, no big difference.
-Maybe spring is different?
-Is there made some changes to crankshaft? (As many you know the partnumber didn't always tell the thruth when we talk about gas gas...)
Maybe somebody who have good contact directly to the factory can try to find out what they do the 300 motor after 2006? Berkyboy...???
I'm very pleased to hear good advices!!!
Thats what I found from http://www.tmxnews.co.uk/content_database/gas_gas_2007_range/index (It's data of the 07 GG bikes)
"The 250 and 300 models get a new crankshaft counter balancer, a re-designed exhaust valve and a new Vertex piston. The changes made to the 125 are designed to simply improve performance, while the modifications to the 250 and 300 are to further smoothen the power, so Gas Gas claims."
I check it and exhaust valve and crankshaft counter balancer really have a different part numbers after 2006. Maybe there is the secret...?
