Noel
Power valve nut
Hi Guys
I pulled my power valve assemeble apart last night (07-250ec) and discovered a nut at the end on the LHS valve assembly. (I'm the 2nd owner). I havent seen this nut described or illistructed anywhere before, is this normal or has the previous owner done some modifications, note the keeper plate was installed as well.
Also is it normally possible to pull out the PV flapper valve out the exhaust opening, as I cant, I want to avoid removing the head and cylinder if possible.
Hi Guys
