Proper coolant level
bluespark
For 2 years I've been running the coolant level on my 11' EC 300 just over the top of the fins, similar to my previous KTM's. I just read the owner's manual and it said to fill to just below the filler cap. I havn't had any problems with over heating or anything, just wanted to hear what others are running in theirs.
Even if you fill it that high, it is going to expand when it gets hot and purge out the overflow... finally settling just over the top of the fins.
I use to top up every ride until I realized that once it settles to the top of the fins, it doesn't drop after that. Unless of course you have a serious boil over!
I took me a few years to realize the right way, which is just like you are doing.
As above. The hotter it gets, the more it expands, and the more it will purge. If it's overfilled it will purge at normal running temp - and if you keep topping it up it will continue to purge.
My fluid level also sits just on top of the fins. If I add more in it'll be fine until I work it really hard and it'll blow a bit more out.
