Here is a new performance enhancer for the gasgas 250 and 300. This is a complete carb mod to help with some of the problems that some people experience with low end throttle response and want to get the best performance out of their bike. I have been working on this mod for the past year now and field testing has gone extremely well
This is not just another jet kit; it's a complete carb make-over that helps with the over-all tune-ability for all situations from the very bottom-end through the top-end.
This mod is not meant to compete with other jetting kits out there, its taking carburetor tuning another step higher.
Your stock carb is bored to 39 mm (a little better top-end) and my proven divider plate is installed (helps with low to mid range throttle response and tune-ability). The low speed circuitry is modified along with the slide, this helps bring the mixture screw into play. The mixture screw now becomes a very sensitive fine tuning tool for altitude and temperature changes.
The carb mod will come jetted very close and ready to ride, plug and play so to speak (Note! Some fine tuning maybe necessary). As this is an “Experimental” carb modification with on going research and development, your feed back will be very instrumental in the on going refinements of this product.
Thank you,
Ron
Thank you,
Ron
