rear wheel situation
rdbandkab
Hi all,
Just replaced the rear wheel bearings on my 05 ec300. A 6004 in one side, and a 6004, a washer/spacer provided by GG, and a 6204 I believe in the other side. Everything turns smoothly...until I put some torque on the axle nut. Then the wheel doesn't want to spin freely..
Any suggestions are appreciated! (funky bearing? bad outer spacers? bad inner spacer?)
rdb
Looking forward to the responses on this one. I've noticed that (just like a Kawasaki I had with only 2 bearings) its sensitive to overtorqueing. Make sure you don't go past the recommended 98nm, which seems high to me. I've tried less, like 70nm, but didn't help much and the chain seemed to loosen some after riding. The adjusters should keep this from happening tho no ?
My KTM that uses 80nm spins nice and free with the same setup and a new tight chain.
My thought is the axle is wearing and without weight on the bike, the wheel is spinning without any help from the bearing.
rdbandkab
I'd bet you're over torqued.
It's also possible that the inner aluminum hub washer (spacer-found between the drive side bearings) has been slimmed if it was overtorqued before.
Did you press them in or tap them in?
Also did you put pressure on the inner or outer races?
Did you change wheel spacers or seals?
Are you sure that you have the right parts? I checked the 2005 parts catalog and I see different numbers listed. Also, did you remember to put the wheel spacer (35) back in during reassembly?
As shown below in the diagram,
Bearing (36) on brake side = 6004
Wheel spacer (35)
Inner Bearing (8) on drive side = 6204
Washer (58)
Outer Bearing (59) on drive side = 6005
from what i've been told, you'll be using 2 6004's and no 6005 bearings with the 6204. a misprint in the later manuals?
I'm thinking I smashed the little bearing spacer just enough..(or the seized bearing, aka the bearing that froze and caused this mess, ground enough spacer material to make it too thin). Any thickness specs on that spacer?
Middle hub spacer looks fine. Might look into new outer spacers also.
One more thing. I also noticed some space between the swingarm and the outer wheel spacer when i mount the tire and start running the axle through the other side of the swingarm.. Like i'll be pinching the arms together when I tighten down the axle nut.
Oh well... thanks for the info and suggestions!
<snip>
To clear this up a bit...
I'm sorry, but you are incorrect about the bearings needed;
but you are correct about the mistake in the parts book. There is a mistake with the bearings shown. It has been incorrect since the 2003 parts manual came out. :(
It should show two 6004 and one 6005 being used.
On your bike (or any 2003 & later), the 6005 bearing should be the one used in the outside position on the sprocket side of the rear wheel. (An exception might be if the older left outside wheel spacer were used with the 6204, but I haven't thought that one through all the way. :) )
The 6204 bearing (which is the proper bearing for this position on the 2002 & earlier models) will fit in your hub, but the will not have the proper interface with your left rear wheel spacer.
On the '03 & newer Gassers, the left rear outside wheel spacer slips inside the inner race of the outside bearing The 6005 bearing has a larger inside diameter to accomodate this. On the older GG bikes, the left outside spacer just butts up against the 6204's inner race.)
I think that your inner spacer is probably deformed enough to allow the outside bearing to bind when the axle is properly tightened.
Good luck with this. Please let us know how it goes.
Jim
figured it out....(sort of.....i know what i have to order anyway)
I think the bearing spacer(or whatever you want to call it) and/or the outer(drive side) stepped aluminum spacer got damaged at some point. I'm thinking either I smashed the bearing spacer removing the bearings or it got worn down by a frozen bearing. In any case....what was happening to bind the wheel was, the "outer" aluminum spacer(drive side) was bottoming out and putting a load on the larger outer bearing's inner race(which, as far as I can see, isn't a continuation of the solid tube your trying to create to run the axle through, instead of bottoming out on the weird thin spacer(between the two bearings) which is against the inner bearing's inner race. Whew....
Anyway... when I tightened the axle nut, it pushed the aluminum spacer into the big outer bearing.. Since its inner race really didn't have too much support, the outer bearing bound up.
The simple fix for the weekend was to grind out a washer that would have an inner diameter that would fit around the axle, but would be small enough to drop through the big outer bearings inner race. This made a solid connective tube from the brake side aluminum spacer-which rests on the inner race of the brake side bearing-which rests against the aluminum hub tube, which rests against the small bearings inner race(drive side)-which is against the flat weird bearing spacer thing-which rests against my hogged out washer-that rests lastly against the stepped aluminum outer spacer.
Anywho..... I either "shortend/smashed" the stepped alum spacer or "smashed" the wierd bearing spacer.....which left a little gap between the outer alum spacer and the inner bearing's inner race.
looking at the diagram above, your trying to make a solid "tube" with numbers 10,36,35,8,58, and 37. That's my theory anyway....ha ha ha.... I may be wrong.
that was probably too long and confusing!!!!
Jim
Sry I have to push up this old thread as I have to change my bearings on my '06 300...
The rear wheel binds and I'm a little confused bout the right bearings to use. The microfiche from gasgasmoto.es say I had to use 1 6004, 1 6204 and 1 6005. (Up to 2014).
The 2015 fiche says 2 6004 and 1 6005 just like Jim Cook mentioned.
So could someone plz tell which ones to use as I d like to get rid of that binding :-(
Can it be that it lasted 11 years till gasgas has the right parts in the fiche?
Rob
Rob
As others have noted, I think after 2003 the parts changed and have remained the same at least through 2010 - maybe through to 2015 but I dunno for sure.
I have a 2010 and the parts listed below for sure work - I noted the parts from an old Jakobi post in a thread re: bearings or the stepped spacer or something like that. Don't forget, the stepped side on the spacer goes to the outboard side.
Rear Wheel:
Seals 1 of each (mm) - 32x47x7, 25x42x7
Bearings - 6004-2RD x 2, 6005-2RD x 1
Front Wheel:
Seals (mm) - 30x42x7 x 2
Bearings - 6905-2RD x 2
Rear Wheel:
Front Wheel:
Hey JP4!
Thx for the info, I'll try that. Have my spacers and washer already, now going to get the SKF bearings. :)
Oddly enough my rear wheel was binding as well. I ordered an aftermarket bearing kit from GoFasters.
Does anyone else's wheel spacer on the rotor side have a lip on it ('06 EC300)? Just making sure mine isn't mushroomed from being over-torqued. I grabbed a hardened sprocket side spacer from GoFasters but they didn't have the rotor side in stock so I want to be sure mine is OK....
Hey all,
just wanted to say, that both my rear wheels ain't binding anymore cz of the "new" washer! :-D
Thx to everyone who helped me
And yes ECTim, the two spacers I got have a lip too, even the new one ;-)
greetings from austria
muellersq
Hey all,
muellersq
Thanks.....is that lip on the end that seats into the seal or the outside that the axle enters through? Mine has a lipped edge on the inside (hub side) that is rather thin leading me to believe it is mushroomed a bit. Both of the outsides have an edge to them but it's pronounced and definitely how it should be. Only my rotor side has the lip on the inside.
I have changed everything in my back wheel and with the proper torque and still binds . I've even had the nut come loose. I just change bearings a couple time a summer and just keep riding
The lip goes into the seal and thats what it is made for I think... If you are not sure, just buy a new one and use it. It doesn't cost much. I can make a photo of my new one tomorrow...
I don't know what u mean by "had the nut come loose"? Excuse me, I'm austrian ;-)
You mean, u change bearings a couple times a year? There must be something wrong...
Does it bind after being torqued? Do u use the right washer and the right bearings? Do u mount the bearings properly and is the inside of the hub in proper condition? The axle could have been overtorqued and is not straight anymore...
The lock nut ( that's what we call it in Canada) to the axle. I have changed everything axle spacers the washer that goes between 6004,6005 bearing. The wheel turns free but not as nice as the yamaha's I have.I buy skf bearings and repack them before I install. Most of the time I am riding in nasty terrain . I have never looked into the hub been damaged, it has always been that way since I got the bike. by the way the best bike I have ever owned
Make sure your axle is inserted on the brake side with the nut placed on the drive side. Also, your axle has a "pull" or nub on the end opposite the threads; make sure it isn't twisting up and hitting the frame when you tighten things down.
Hope this helps.
Also, some of the center spacers (aluminum ones) were known to have worn or swelled just enough to not properly space the bearings. Most replacements are steel as opposed to aluminum. R575700 is the GG part # for my 2010
That's what I was thinking too but wasn't sure. Go figure, the right side spacer is on back-order from Spain.
If you could post a pic of your new one that would be great. Much appreciated!
