Recommend me a needle :)
motopsycho87
Hi everyone!
I've currently got my bike jetted at
Pilot - 42
Needle - CEK 3rd clip
Main - 178
The bottom and top end feel great, but I have a flat spot in the middle (I've played with power valve shims, and am at my most pokey), I'm also suffering 4 stroking at high rpm with constant throttle (not under acceleration).
This is on a 2006 EC300 with the round top PWK38 (AS1?), at sea level with ambient temperature from -10 to 30 centigrade (currently about the 20's). Can anyone recommend me a needle? Dropping the CEK to the 2nd clip makes the bottom end quite weak, and only helps the 4 stroking a little bit.
Thanks!
No recommendations, but constant throttle burble is related to throttle position, regardless of rpm.
07 yz250 needle, n3ew middle position. Really leans out the mid range. Might have to bump up the main to a 180 if you are on the pipe a lot.
yep mines a N3CJ, 3rd clip, 175 main and cannon silencer - runs sweet
KTM also sell the same needle cheaper
Hi everyone!
Pilot - 42
Main - 178
Thanks!
Granted each bike can run with different jetting setups, I think you may be a little lean on clip position and could be lean in the middle. Going to the fourth position with a CEK is the same as a CCK in the 2nd. I run a 42 and a 178 and CCK in the 2nd and I'm running at 2,500 to 4000ft at 25C. At your temp and elevation I'm quite sure I'd be lean.Try the fourth position.
I also like N3CG (3) with a 42 and 178. Going back and forth from N3CG (or EG) to the CCK I do have to adjust the air screw to get the ideal low end response. The N3's seem to be a bit richer in the first 3/8's or so of throttle compared to the CCK. I will run the CCK at about 1.5 turns out but the N3CG at 2.25 or 2.5. The N3CG is just a half clip leaner than a N3EG.
This is on a 2006 EC300 AS1 with RB head mod.
Holy crap! It works! N3EG in 2nd clip is absolutely amazing!
Ever since I changed my gearing and put supermoto wheels on I've struggled to get the jetting right (problems are WAY more obvious with taller gearing). Finally this has given me smooth and aggressive power from bottom to top!!!
My main problems were a flat spot in the middle and overly lean at constant throttle at high rpm (4 stroking) all gone :D!!!
i run a N3Eg in both my 250 and 300 both 09's...ASI carby (round top). pj and mj are very different in each bike (cant quite remember what) but the 300 runs way leaner jetting than the 250. on middle clip in each..... both go like hell and pull hard off the bottom and both will idle at stupid low rpm's for ages...
I just received my two new needles in the mail,N3EG and N3CG. I pulled my carb apart, it had 40 pilot, 178 main, CHN needle(wtf?) on the 4th clip from the top.Does anyone know much about this CHN, I heard it was a super lean needle for emissions testing. I was wondering why the dealer stuck this in my ride. I was thinking about ordering a 42 pilot and going with the N3EG. Or to try the N3EG with the installed 40 pilot and the installed 178 main( top end is good she howls like a demon.)? Also, does the slide have an identifying number? I ride in Florida, extremely humid, super high humidity, 0 to 100 feet or so above sea level and usually in very deep sand.
