remapping after throttle body been off
jenkitchen1006
hi there can anyone tell me if once you'v had the throttle body off put a diffrent injector in and tried a different throttle body sensor do i have to have software to set the bike up again ,or will the standard settings be stored in the ecu, sorry about all the questions im a bit new to gas gas
Values should be fixed as it is a very rudimentry system, dis- connect and re- connect the battery neg wire.
If you have had the throttle position sensor (TPS) of it will pay to use VDST software or similar to do a TPS reset. As long as the injector is rated the same as the original the fueling should not change or need adjustment.
